Originally Posted by cabntmkr
The oil is dripping slightly off center on the passenger side back by where the engine meets the transmission. Haven't jacked it up yet to take a better look. Will probably take it back to the dealer this week and have them put it up on the lift.
That sounds like the dreaded transmission connector leak. Check out the threads on here. There are some DIY instructions to fix it. Also, info on what to be aware of if you take it to a shop to have the work done. If the connector comes off like it should, the fix is pretty inexpensive (80-120 bucks). The part is only about 15 bucks. If it doesn't, and the internal connector screw is stripped, things get complicated and more expensive. Good luck.
