Old Jan 5, 2011 | 07:43 PM
  #47 (permalink)
onehundred80
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
I may be young, but I prefer the tried and true methods. If you remove the spring, you have that much greater of a chance it is going to end up in your headlight housing. After having these things out of the car and experimenting with different ways to do this, I will stick to my method for now, but thanks for the advice
This thread reminded me that I had still to add the HID setup to the passenger side. I found that it was harder to fit the spring back on that side, I do not know why really as the tank was out and the hose was tied back. It took me a couple of minutes this time, somehow I fumbled around more. The bulb aligned correctly though first try, like the other side did.
I'm going to try the Ultras on the high beams, I'll see if they are a bit whiter, the highs now look like yellow fog lamps compared to the HID's.
