HOW TO replace headlight bulb. Pictured step by step instructions
Old Jul 16, 2017 | 01:40 PM
  #181 (permalink)
KeithTexas's Avatar
Smile Re: HOW TO replace headlight bulb. Pictured step by step instructions
Hi all,
I just got a 2005 Crossfire a few weeks ago. This forum is fantastic!
My low beams were only projecting a few feet in front of the car. Yep, the low beam bulbs were not seated correctly. I followed the advice here and was careful with the clip and I got both bulbs aligned and seated.
My driver side bulb was off by about 45 degrees. The passenger side bulb was 180 degrees off.
Thanks everyone for all these great posts.
Old Aug 2, 2017 | 07:37 PM
  #182 (permalink)
mugsy99's Avatar
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
Do you still have headlight clips? Looking for 2004 coupe passenger side.
Old Aug 2, 2017 | 07:43 PM
  #183 (permalink)
I have them, they are universal.
usually $10 each incl shipping in US.
I'll have to check rate to Canada, don't wish to lose money on them.
IM me with your address and I'll reply with my paypal info.
Old Dec 9, 2017 | 05:51 PM
  #184 (permalink)
Jeffr0's Avatar
Thanks a million Musclefan21 - I'd never have figured this out without the pics and tips.Installed 2 headlamps today without a hitch.....but not without a few swear words. It's a tight job! One question- pretty sure that I seated the bulbs correctly- but is it the case that the drivers side and passenger side bulbs seat differently? Seems they were 180 degree opposite.
Old Dec 9, 2017 | 06:56 PM
  #185 (permalink)
As far as I recall. it's the high and low beam bulbs that are 180 deg different on each side.
Old Dec 9, 2017 | 07:41 PM
  #186 (permalink)
Jeffr0's Avatar
Why would they do that? All the bulbs are the same, the housings are the same. It doesn't make sense. But it wouldn't surprise me.
Old Nov 9, 2018 | 05:25 PM
  #187 (permalink)
jrhack's Avatar
Musclefan mentioned not being able to put the spring back after taking it out rather than lifting it up out of the way. Here is a view of the spring and its mounting points.
Just put one end in place and flex the spring enough to insert the other end.
Yeah I know, easier said than done, use needle nose pliers and a mirror, if you are nervous about it springing away tie a thin piece of string or thread to it and tie the other end down.
You mentioned that here is a view of it, but I didn't see any pics. When I tried to replace one of my 2006 Low-Beams, the spring clip fell out, and either went down in the Headlamp assembly or got stuck under engine compartment. Do you know where to get replacement spring-clip, and if you can refer me to the pics of putting it back on would be most appreciative. Thanks.
Old Nov 9, 2018 | 06:37 PM
  #188 (permalink)
Photo of clip attachment. CLICK To get at the clip you have to remove the socket from the bulb.
You can get this spring clip. CLICK
or this one. CLICK
Old Sep 21, 2019 | 01:01 PM
  #189 (permalink)
Bono's Avatar
My clip is missing, passenger side headlight, how the hell do you get one back on, I'm not having any luck.
Old Sep 21, 2019 | 07:12 PM
  #190 (permalink)
The post in front of yours shows the clip in position.
If you look at my sig line you can see a link to a large post, look up ‘lights’ and see where you can buy the clip.
Remember SEARCH is your friend.
Old Nov 21, 2019 | 03:43 PM
  #191 (permalink)
KeithTexas's Avatar
or this one. CLICK
Hey! This photo looks like it is reversed. The markings on the base of the bulb look backward to me. You must have taken it with a mirror!!! Clever fellow!
But, in any case, it's a great photo and sure helped me.
I'm just commenting because this morning, I thought I would replace my low beam bulbs in a few minutes and then that !@#$% clip came loose on the passenger side. I honestly didn't think I could get it back into place. You're working blind with one hand to slip the spring back into the little supports.
Thanks onehundred80.....
Old Nov 21, 2019 | 04:52 PM
  #192 (permalink)
As I recall that photo was taken using a mirror as my SLR camera would not fit.
Old Dec 2, 2019 | 05:08 PM
  #193 (permalink)
dentdaddy's Avatar
Exclamation Re: HOW TO replace headlight bulb. Pictured step by step instructions
I don't know if this conversation is still active in any way but I thought I would reach out. I changed the low beam bulb with little trouble but I can't get it to stay burning? Like the base of the bulb grounds to the housing or something? Any thoughts? Thanks in advance for any help.
Old Dec 2, 2019 | 06:43 PM
  #194 (permalink)
The bulb uses the two wire tabs, they do not ground to anything. I suspect you got a bulb with a broken filament and it makes/breaks contact at will. Get a different bulb, I suspect your problem will go away. If you have an 'OHM' meter, attach the leads to the two tabs and tap the bulb base. See if it moves the meter. If so, again, bad bulb. Good luck!
Old Jan 6, 2020 | 08:32 PM
  #195 (permalink)
Garco57's Avatar
Are both low and high beam bulbs the same H7??
Old Jan 6, 2020 | 08:40 PM
  #196 (permalink)
jrhack's Avatar
Garco57 - Yes they are.
Old Oct 16, 2020 | 04:27 PM
  #197 (permalink)
alauth56's Avatar
has anyone added an H7 LED? Not sure if the retaining spring will ever work with the big cooling fan on the rear of the bulb housing?
Old Oct 16, 2020 | 04:41 PM
  #198 (permalink)
alauth56's Avatar
never mind, figured it out. The locating ring comes off, secure with spring clip, insert bulb last!
Old Feb 8, 2023 | 07:26 PM
  #199 (permalink)
Tlittle1's Avatar
What do you do if the clip came loose? I can’t see where to reattach it. I got a feeling I will have to remove the lens to get to the place where they fit.
Old Feb 9, 2023 | 07:37 AM
  #200 (permalink)
mugsy99's Avatar
Not a big deal, do you have the clip? As long as you still have the clip, and it’s not lost it can be installed anytime. I have got a small hand guy at auto parts store to do mine a few times.
waldig
Jul 31, 2017 09:46 AM
axnguyen
Jul 21, 2015 11:41 AM
waldig
Jul 20, 2015 08:10 AM
waldig
Jul 15, 2015 02:05 PM
tom2112
Jul 12, 2015 04:41 PM
