onehundred80
Musclefan mentioned not being able to put the spring back after taking it out rather than lifting it up out of the way. Here is a view of the spring and its mounting points.
Just put one end in place and flex the spring enough to insert the other end.
Yeah I know, easier said than done, use needle nose pliers and a mirror, if you are nervous about it springing away tie a thin piece of string or thread to it and tie the other end down.
You mentioned that here is a view of it, but I didn't see any pics. When I tried to replace one of my 2006 Low-Beams, the spring clip fell out, and either went down in the Headlamp assembly or got stuck under engine compartment. Do you know where to get replacement spring-clip, and if you can refer me to the pics of putting it back on would be most appreciative. Thanks.
