Old Dec 2, 2019 | 06:43 PM
  #194 (permalink)
GraphiteGhost
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
Originally Posted by dentdaddy
I don't know if this conversation is still active in any way but I thought I would reach out. I changed the low beam bulb with little trouble but I can't get it to stay burning? Like the base of the bulb grounds to the housing or something? Any thoughts? Thanks in advance for any help.
The bulb uses the two wire tabs, they do not ground to anything. I suspect you got a bulb with a broken filament and it makes/breaks contact at will. Get a different bulb, I suspect your problem will go away. If you have an 'OHM' meter, attach the leads to the two tabs and tap the bulb base. See if it moves the meter. If so, again, bad bulb. Good luck!
