Dead battery
Old Feb 8, 2023 | 06:26 PM
Tlittle1's Avatar
Default Dead battery
I have. burned out headlight; if I let my crossfire sit in garage without starting the battery will be dead, could a burned out headlight be the cause? I am currently attempting to replace light; electrical plug is being stubborn
Old Feb 9, 2023 | 01:24 PM
Padgett's Avatar
Default Re: Dead battery
No. Way I use to find is to put a trouble light (incandescent, not LED) in series with the battery after allowing it to sit for long enough to turn everything off. Should not glow. If it does then start pulling fuses and relays until it goes out. That is the circuit to check.
sshistand@fuse.net
68
Jul 5, 2024 03:30 PM
MCPO
Apr 28, 2023 01:31 PM
phil alvirez
Oct 2, 2019 11:09 AM
angelomd
Dec 7, 2014 06:22 PM
ProjectMayhem
Jul 14, 2008 07:16 PM
