HOW TO replace headlight bulb. Pictured step by step instructions
Old Jun 20, 2014 | 06:47 PM
  #141 (permalink)
cg80's Avatar
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
Some companies just want to spoil your fun all the time.
Solution.
Retire, don't get old, just retire.
I always said why work until 65, we should be able to start work at 65 and work till the end.
  • Old people forget everything at that age, so even though they will have lots of experience it will not help because they'll not remember it.
  • It will take more people to do the same amount of work, so the unemployment figures will go down.
  • No worry about any low pay because they will not be saving for their old age
  • No retirement plans needed.
  • The saying 'I'm getting worked to death' will be true.
You get the drift.
Dave: I just love and want to ditto your assessment of old age...priceless and true>>>LOL...Carl
Old Jul 6, 2014 | 03:57 AM
  #142 (permalink)
transmogrifier7's Avatar
Unhappy Re: HOW TO replace headlight bulb. Pictured step by step instructions
Hi all im having problem finding "how to change bulbs" my tiny side light in headlamp has gone,iv tried and tried but cant get it out HELP ! PLEASE
Old Jul 6, 2014 | 07:38 AM
  #143 (permalink)
10 mm open end wrench and some angled needlenose pliers will do the trick.
Old Jul 6, 2014 | 07:43 AM
  #144 (permalink)
Thanks il try that.😁
Old Jul 6, 2014 | 08:10 AM
  #145 (permalink)
This is not a new problem. CLICK
Old Jul 17, 2014 | 05:29 PM
  #146 (permalink)
jimmier's Avatar
Need a little reassurance that the socket comes out just by pulling. I have read this thread and am working to replace the passenger low beam. I can reach the socket (circled part in picture 3) but as hard as I pull it won't come out. I'm about to grab it with a pliers and try. Anybody else had this hard of a time.
Old Jul 19, 2014 | 06:58 PM
  #147 (permalink)
jimmier's Avatar
OK guys. Please help. I pulled and pulled on the socket for the passenger low beam. It finally came off along with the bulb and the spring. So since it seems impossible to replace the spring that holds in the bulb I figure I need to take out the whole light assembly. Loosened the four bolts that hold it in but can't seem to get the assembly out. Seems like it is too big to move forward out of the body trim. What am I missing?
Old Jul 19, 2014 | 07:04 PM
  #148 (permalink)
Mrmiata's Avatar
Haven't been the done that.. but what I've read says remove the bumper cover.. "might" be able to loosen that side enough to wiggle it out?
Old Jul 19, 2014 | 07:29 PM
  #149 (permalink)
If you have the 4 mounting bolts removed, the eyebrow light removed and the harness disconnected, then remove the screw-in adjusters on the bottom two attachment points. This will give you JUST enough extra room to get it out.
When you put it back in, screw the adjusters in about 1/3 of the way ( after it's in place ), put the eyebrow light back in, connect the harness, secure the 2 top bolts then screw the bottom adjusters in until they just contact the body mounting tabs. You can now insert and tighten the two bottom bolts.
Old Jul 19, 2014 | 08:37 PM
  #150 (permalink)
jimmier's Avatar
Just had to remove the screw on top and just to the right of the headlight assembly. That let the whole front panel flex just enough to get the assembly out. Once out, replacing the clip and the bulb was a no brainer. But what a PITA job just to replace a bulb. Can't believe how tight that socket was on that bulb. Only way to separate socket from bulb was to put a screwdriver between the two and pry. Once I had the battery negative cable disconnected and then reconnected I thought I would have to go through all the black magic to disarm the seatbelt chime again, but it still seems to be disabled. If reconnecting the battery doesn't do it I wonder what does. I don't miss that thing so I am glad it is still quiet. Thanks to all for your help. Glad to be associated with such a great forum.
Old Aug 16, 2014 | 06:06 AM
  #151 (permalink)
Jesticle's Avatar
Thanks for the write-up and pics. I wasn't 100% sure that the connector wasn't attached with a clip or anything, until I saw your pics. Took 5 minutes to replace the passenger headlight.
I have very strong hands from my job, but that stupid connector took a solid 2 minutes of pulling before it popped off. At first I thought I broke something, but all is well. I wasn't anywhere near my toolbox, but next time I'll use some 45 degree needle nose pliers instead of my fingers
Use surgeon type nitrile gloves to avoid getting oils from your skin on the new bulb
Old Aug 20, 2014 | 07:08 PM
  #152 (permalink)
A year ago you had problems and never did tell us the outcome and how you solved the problem, we'd like to hear what cured it, especially those that tried to help you.
Old Aug 23, 2014 | 01:27 AM
  #153 (permalink)
Jesticle's Avatar
I can't remember last night, let alone last year.
Old Aug 29, 2014 | 06:09 PM
  #154 (permalink)
srt10's Avatar
Just used the picture illustration to change my head light bulb, good instructions
Old Oct 13, 2014 | 03:32 PM
  #155 (permalink)
Luc3348's Avatar
Originally Posted by cpethybridge
Hi! This was great, but my light is different. I am a complete noob, but I think the previous owner put in a custom light, and the connection at the bottom of my bulb doesn't look like it comes apart the same way. I'm adding some pics (I think). Can anyone tell me if it's okay to try to yank this apart?
Hi!, i do have the same kind of light but blue, just bought the car and wonder where to buy those blue light. they are 35 watts 8000K
Old Oct 18, 2014 | 01:10 PM
  #156 (permalink)
stlouisramsfan's Avatar
Thanks, this saved a lot of time!
Old Oct 28, 2014 | 02:07 AM
  #157 (permalink)
tenarr's Avatar
This is crud. I have a 2006 coupe and there is no way that it can be changed like that. I almost lost a marriage over that headlight. Please.
Old Oct 28, 2014 | 10:59 AM
  #158 (permalink)
Them is mighty strong words, Pilgrim.
I'm all thumbs and half blind, but was still able to do it, all four bulbs !
Old Nov 2, 2014 | 05:18 PM
  #159 (permalink)
tastegw's Avatar
Step 3 I can't seem to do, pulling out the connectors, any tips?
Edit: just finished reading entire thread, will try needle nose, if that doesn't work, off to a mechanic :/
Old Nov 4, 2014 | 05:15 PM
  #160 (permalink)
tastegw's Avatar
After autozone, Midas and myself failed to disconnect the wire plug, a truck mechanic at my work place was able to do it, then he took the pin out as I was telling him to leave it in lol. 30 min later he finally got the pin back in and I'm good to go on the headlight now
