Old Jul 19, 2014 | 07:29 PM
  #149 (permalink)
ala_xfire
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
If you have the 4 mounting bolts removed, the eyebrow light removed and the harness disconnected, then remove the screw-in adjusters on the bottom two attachment points. This will give you JUST enough extra room to get it out.
When you put it back in, screw the adjusters in about 1/3 of the way ( after it's in place ), put the eyebrow light back in, connect the harness, secure the 2 top bolts then screw the bottom adjusters in until they just contact the body mounting tabs. You can now insert and tighten the two bottom bolts.
