Old Jan 12, 2011 | 03:14 PM
  #71 (permalink)
LantanaTX's Avatar
LantanaTX
Default Re: Project Log: 320 to AMG/SRT Level
Originally Posted by Teck-9
The DCAI will, as the V8 dimensions are the same, the 2 extra cylinders are in the front. the TB is in the same location as with the V6. The plugs and wires are obvious, you just gotta get 4 more of each. The pulley kit I'm sure will, as the pulley system on the 8's look the same as the 6. They're the same engine with 2 more cylinders. The exhaust is custom made by Rob @ NW and he said he can make it fit a 6 or an 8, whatever I want, The only thing that won't go over is the ECU tune, obviously. I'd love to know Lantana's progress with turboing his 500. If that's possible, then deal sealed. I've always wanted a 500.
You are pretty much correct about transferring the parts over to a V8. One of the front spark plug wires is actually longer than the others, so you would have to specify spark plug wires for the front plug on the passenger side. The exhaust is just slightly different and the head pipes will need to be slightly modified to match up with your down pipes. all the front belts and accessories are the same on the V8. A turbo is not ruled out for me but I have found a proven supercharger kit for my V8 which in a SL500 put 385 to the wheels. I think I may be able to do a little better with a NW super cooler and boosted and tuned for 93 octane instead of 91.
