Old Jan 13, 2011 | 04:26 PM
  #85 (permalink)
Bladecutter's Avatar
Bladecutter
Default Re: how many miles on your xfire? major problems?
Originally Posted by XFire-GTO
Quick question....... just bought a 2005 Limited Coupe and this is one of several issues, won't go into the others at this time.
Only received one (1) key ..... the Red Button for the panic button was cut out (red rubber)... why I have no clue..... from reading the manuel I'm under the impression that needs to be pressed to set the Alarm system.... is that correct?
Or is the alarm system automatically activated when pushing the Lock Button?
Thanks!
Alarm system is activated when you press the Lock button.
The Panic button is if you are being mugged.
You press and hold the Panic button for several seconds, and then the alarm system on the car goes crazy, causing the mugger's ears (and yours too) to start bleeding from the high pitched wail.
Dogs will go crazy, and attack anyone in the vicinity, so make sure to get into your car and lock the doors before the dogs kill everything in site.
The alarm is really annoying, and hurts, if you haven't gathered yet.
BC.
