Re: Project Log: 320 to AMG/SRT Level
You are looking at a wild dual turbo set up on a 112 MB V6. It looks like they reversed the exhaust manifolds to point up.The wrapped pipe is the exhaust pipe going to the turbo. The charge pipe out of the turbo is going to an air to air inter cooler in front of the radiator and condenser with the yellow pipe is bringing the charge to the throttle body with dual blow off valves. Pretty cool set up! I bet he is using an AEM IFC-6 to tune it. Not sure if he is running a MAF. It is not a good idea to blow through the MAF. You want to suck through it if you can't eliminate it.
check out this turbo!
http://www.themotorreport.com.au/594...lineup-by-2010
