Old Jan 22, 2011 | 12:02 PM
  #49 (permalink)
onehundred80
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
I agree, and with everything in my car being LED or HID (even the fogs) they look even more out of place. I do not mind though, because I rarely have to use them with the increased light output from the HIDs and when someone who would not normally notice HIDs is looking at the car, I can flip on the old highs and WOW then they can see the upgrade
I took a photo of the HID low 4300K and the Ultra high beams on a gypsum board two feet in front of the headlight. The high beam looks like an omelet on snow.
The second picture is the standard bulb and HID. Frankly I cannot see much difference with this setup. I'll take the car out sometime and shine them on the garage door.
Changing the bulbs in the high lamps is a real pain, I would not take the springs out to do these highs unless the unit was on the bench. The lamp unit is not in line with the access hole and the spring comes only half down and hits the opening. As a result the bulb insertion is inhibited by the spring which is in the way. Who ever designed these units needs a lesson or two in design.
I wonder if a dual HID setup is feasible?
