Old Jan 31, 2011 | 06:59 AM
  #69 (permalink)
XFire-GTO's Avatar
XFire-GTO
Default Re: How to program your own key. SAVE $$$
Originally Posted by Shawnkey
This is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
Shawn
Thanks for the info
https://www.crossfireforum.org/forum...tml#post562371
