Old Feb 2, 2011 | 08:46 AM
onehundred80
Default Re: Do HIDs need a relay?
Originally Posted by Kolme
What i ended up doing was buying 55watt HID kits. I installed them without relays.. B/c of the 55watt supply, i no longer get the "light out" warning, and I havent had a single problem with the lights since the install which was about 8 months ago.
This infers that 55 W kits will not give you the light out problem. I have a 35 W kit and I have no problem.
It is a problem with the older kits, they have now generally corrected the problem that caused the light out bulb to be illuminated.
My system does not use relays and neither do the newer systems.
