Old Feb 3, 2011 | 02:46 PM
  #338 (permalink)
antonio311's Avatar
antonio311
Default Re: WOW ... stop the rust while you can ...
There are drain holes on each side of the door. Probably they are all clogged up and the water isn't draining out of the door. I fully suggest that u use an air compressor with a nozzle to blow into each drain hole so they get unclogged. Then run a water hose into each side so it clears out the debree & dirt. Then again use the compressed air to move that water out. You dont have to get all the water out, just most of it & the rest will dry it's self. I use this method myself & drain plugs MUST be clear!
