Old Feb 3, 2011 | 04:57 PM
  #340 (permalink)
onehundred80
Default Re: WOW ... stop the rust while you can ...
Originally Posted by antonio311
There are drain holes on each side of the door. Probably they are all clogged up and the water isn't draining out of the door. I fully suggest that u use an air compressor with a nozzle to blow into each drain hole so they get unclogged. Then run a water hose into each side so it clears out the debree & dirt. Then again use the compressed air to move that water out. You dont have to get all the water out, just most of it & the rest will dry it's self. I use this method myself & drain plugs MUST be clear!
I would not suggest blowing compressed air and water up the drain holes, who knows where the water will splash. It will only blow the debris away from the hole and it may stay away from the hole for a while and then return to plug the holes again.
The debris may be too big to come out of those small holes anyway.
The only way to clear them properly is to remove the door liner and clean it out and inspect for rust, but it's your car so it is up to you.
