Old Feb 5, 2011 | 11:27 PM
onehundred80
Default Re: Oil warning light flashing periodically
About 4 or 5 months ago someone also posted that they had to replace the oil level sensor sending unit. If I recall it was not a simple or cheap fix. Have you tried a search?
You could start here :https://www.crossfireforum.org/forum...oil-light.html
Before getting too worried check the wire connector that must be around the bottom of the crankcase somewhere, I have no clue where.
Check the simple and cheap things first every time.
