Originally Posted by MAYAman
Great man, now where can I buy these adapters. I went to three different audio places today and they won't divulge where to buy it.
I picked up the adapters I needed for my project from Best Buy, out in the car installation area. Circuit City should have the adapters too. The antenna adapter is a standard one that is used on lots of different cars and the wiring harness is a standard one for lots of VW's. You can also buy them on-line, here's what I have for notes:
Originally Posted by Audio Notes
Crutchfield note:
When used in this vehicle, the functions of the yellow and red wires in the Crutchfield harness are reversed. The yellow wire supplies ignition power, and the Red wire supplies constant power.
Anyhow here's the info from DFWSBR:
Universal OEM DIN Tool Pair (Crutchfield P/N 120869001)
Scosche VW01B Wiring Harness (Best Buy)
Metra Antenna Works 40-EU10 Antenna Adapter Cable (Best Buy)
P/N 120869001 Universal OEM DIN Tool Pair (removes stock head unit)
P/N 12040EU10 Euro antenna adapter
P/N 120701784 VW Wire harness (switch the red and yellow wires when connecting the VW harness to the new head unit harness, DO connect the amp turn on lead)
If you're going to buy them somewhere else, go to Crutchfield and print out the pictures of each item or just shop for head units that fit your Crossfire and add one to your cart and the other items will be added automatically.
