OK, finally got all my audio components. Please tell me what I need to hook up to
Old Aug 13, 2005 | 08:35 PM
MAYAman's Avatar
Default Re: OK, finally got all my audio components. Please tell me what I need to hook up to
OK, I got everything hooked up but I get no sound. So I'm guessing I have the amp wire not hooked up correctly. Please if anyone knows which wire on this harness and which wire on the Kenwood KVT-M700 would allow me to use my factory amp I would greatly appreciate it.
Old Aug 13, 2005 | 11:17 PM
stryfox's Avatar
Kenwood usually uses a blue wire as the signal power on wire. I think the factory harness wire was pink, i am not sure i did it about 3 weeks ago.
Old Aug 13, 2005 | 11:28 PM
CyberGreg's Avatar
Okay... you have the VW wiring harness, right? just connect up all the wires to the leads to your Kenwood deck. Anything that doesn't match, don't stress... its cool.
On the VW instructions it says to not connect the amp turn on lead but you DO have to connect this to whatever your Kenwood uses for the amp turn on lead. I'm not much for colors, just whatever the schematic says.
Here's the link to DFWSBR's instructions, he pretty much covers it all.
Link here
As far as the screen over ride goes, I think you usually have to tie them into the E-brake but I don't know if it needs 12 volts or ground. It sounds like it needs a ground, if that's the case just tie it in with the ground with in the VW harness.
Old Aug 13, 2005 | 11:38 PM
CyberGreg's Avatar
Originally Posted by malcb
I like the factory sound system but am surprised that the back speakers are subs only. Does the factory amp have four channels and single sub? Suppose I should take a look. Usually what I try to have is the fader set to keep the sound central.
I'm trying to post another picture but it's not letting me... anyhow the amp is four channels, two front and two rear.
Old Aug 13, 2005 | 11:54 PM
stryfox's Avatar
yes what cyber greg said about the wires, but the factory amp is 2 channels just right front and left front.
The subs are wired to the factory amp so you don't need to do anything there.
Old Aug 14, 2005 | 01:36 AM
CyberGreg's Avatar
oops my bad... of course its only 2 channels... we only run left and right out of the head unit... I believe the amp has a built-in crossover for the subs so it looks like it has 4 channels or rather 4 outputs.
damn it... still can't post the schematic... oh well I will eventually...
Old Aug 14, 2005 | 09:31 AM
MAYAman's Avatar
Thanks guys, job is done and it came out amazing!!! Will post pics soon but I'll tell you the KVT-M700 looks almost factory.
Old Aug 14, 2005 | 10:26 AM
CyberGreg's Avatar
Congrats... by the way, which wire did you use from the Kenwood?
Old Aug 14, 2005 | 01:23 PM
silver98m3's Avatar
I would LOVE to see some photos, especially some screen shots of the GUI on the m700. There isn't a better lcd head unit in terms of matching the interior look than that one.
TerryR
Dec 13, 2019 03:27 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
smokey847
Nov 12, 2015 11:54 PM
o55ie18
Oct 5, 2015 05:50 PM
KDW4Him
Crossfire Events and Meets
15
Sep 30, 2015 08:53 PM
