Old Aug 13, 2005 | 11:28 PM
CyberGreg's Avatar
CyberGreg
Default Re: OK, finally got all my audio components. Please tell me what I need to hook up to
Originally Posted by MAYAman
OK, I got everything hooked up but I get no sound. So I'm guessing I have the amp wire not hooked up correctly. Please if anyone knows which wire on this harness and which wire on the Kenwood KVT-M700 would allow me to use my factory amp I would greatly appreciate it.
Okay... you have the VW wiring harness, right? just connect up all the wires to the leads to your Kenwood deck. Anything that doesn't match, don't stress... its cool.
On the VW instructions it says to not connect the amp turn on lead but you DO have to connect this to whatever your Kenwood uses for the amp turn on lead. I'm not much for colors, just whatever the schematic says.
Here's the link to DFWSBR's instructions, he pretty much covers it all.
Link here
As far as the screen over ride goes, I think you usually have to tie them into the E-brake but I don't know if it needs 12 volts or ground. It sounds like it needs a ground, if that's the case just tie it in with the ground with in the VW harness.
