Re: Oil Leak or Faulty Oil Level Sensor
Yes..there is a leak..it's coming from the actual filter housing..the filter was very loose. Either the largest of the o-rings failed or i have it in the wrong position. Is the large o-ring supposed to be visable when the cap is tightened?? Right now you can see it between the housing and the filter cap.
Would someone please take a picture of how their filter housing looks when the o-ring is put in correctly, or show where the largest o-ring is supposed to go??
