Originally Posted by pete1365
Also $78 for labor to change the oil. Geeze, practically disassemble the engine in that amount of time.
pete1365,
If you have the time, doing it yourself will run you about $55.00 which is the price of oil and a filter. My dealer is charges just $9.00 for the filter.
It's not that hard and probably the cleanest oil change I've ever done.
Simply remove the cover that hides the oil pan, drain the oil, replace the cover, remove and replace the filter which sits "on top" of the engine. That's it. Took about 45 minutes but will be faster next time.
