AAUUGGHHHH!!!!
I went to the tire shop to have the locking lugs removed this evening. The guy THOUGHT he had the right socket/key. He was wrong.
So, frustrated, he asked, "You SURE it is not in the car???" I showed him it wasn't in the car - even took the air compressor, tire sealer and jack out of the trunk.
The key was under the jack.
Sometimes, the obvious is right under our nose and we don't even see it.
A lot, as it was in exactly the spot it should be.
I usually keep the locking lug bolt socket in the glovebox when I've used them. Just makes it easier to get at for work at tire shops and at home. I don't want to have to access the spare equipment out of the trunk storage area unless I have to. Anyway, glad you were able to find it. Now you only need to decide whether to keep the security lugs installed or go back to standard versions.
