Originally Posted by cmac
I just put mine on today. Needs a little more adjustment but it looks awesome. Mine was a bit tight sliding over the hinges but that is a small issue I'll post pics shortly. Haven't. Got the wing put on yet either
Install one bolt at a time left hing, right hing, left hing...... (as one would do on a tire)
Start with the bottom bolts 1st on both sides.
Rear:
Once installed, if you still need the hood to be a little lower in the rear, you can also remove the 2cm nub on the top of each latch. Keep all the bolt lose till you get the best fit in the rear and front.
Front:
Lower the front hood stoppers, and use the hood latch adjustment slots to get best fit.
As far as the CF wing.... 3M Is your best friend!
Call me if you have any questions.
