Old Mar 6, 2011 | 10:24 AM
onehundred80
Default Re: Does Your Hardtop Leak In The Rain?
Originally Posted by belkerx3
Thanks for all the input. Sounds like the weather strip needs to be changed out. Where might a good place to purchase that part?
Again, thanks.
If the glass is staying outside the rubber then the window mechanism needs adjusting. When you are in the car and the door is open, lower the glass, shut the door and then raise the glass. It should come up under the seal.
It is an easy but time consuming job as you have to take the inner door panel off to do the adjustment.
The glass can be adjusted for height and angle (pitch) both of these may be out in your case. Do not let the glass rub against the seal as that would be the worst part to replace.
https://www.crossfireforum.org/forum...tml#post477487
