Old Mar 6, 2011 | 04:26 PM
dedwards0323
Default Re: New TSW Donnington's... *Pics*
Originally Posted by SoftballJunnkie
Dewards, thanks for the all the info its greatly appreciated.
I looked up the center bore and according to the sites its 73.1 and I dont think the tire shop included any hub centric rings. I'll double check with the shop tomorrow.
I have a few questions. If the OD is 73.1 do I go with 73mm or 74mm on the rings?Also can I add spacers to the hub centric rings as well to get my offset back to stock?
Go to the website JustForWheels.com and look up what you need under the application search.
Step 1 - Make of Car
Step 2 - Model Year
Step 3 - Model
Step 4 - Wheel Manufacturer
Result will be the required Hub Centric Ring Set you need. Around $36 per set of 4.
Really simple to do once you know how to use the website. If you're still unsure, give them a call.
