Old Mar 6, 2011 | 08:05 PM
X-fired's Avatar
X-fired
Default Re: blown turn signal bulb, or not?
Aha! I had the same problem and was just poring over the service manual but thought I'd check here before attacking the multi-function control lever. Sure enough, one of the contacts on the turn signal bulb housing wasn't making good contact and it had a hole burned into it. I attempted to solder the hole but ended up just pulling it out a bit as others mentioned.
