Old Mar 7, 2011 | 06:31 PM
dedwards0323
Default Re: ADR Propulsion (machine silver) 18" and 19", 235/40/18, 265/30/19
Originally Posted by Kodebuster
WOW, I'm glad I saw these before I went with the Mandrus Millenium rims.
I like this stying much better than the Mandrus, (but I continue to be torn between the Hyper-Silver and straight Chrome):
https://www.crossfireforum.org/forum...rome-rims.html
I'm running stock size tires from Continental, which I don't wanna change as they have less than 1000 miles on them.
Any issues with getting the right size ADR-54 Propulsion rims to match my current tires...???
Front ~ 225-40 R18 Continentals
Rear ~ 255-35 R19 Continentals
Any input on on the correct size ADR rims for my tires is appreciated...
Thanx...
You'll probably need the following ADR Propulsion Rims:
Front: 18 x 8, 5 x 112, 33 mm Offset, 73 mm Hub Bore
Rear: 19 x 8.5, 5 x 112, 20 mm Offset, 73 mm Hub Bore
Hub Centric Rings: 66.56 mm / 73.0 mm
These ought to fit w/o much fuss with factory size tires mounted. nox1s can chime in to verify.
Here's an eBay link that has these wheels listed in various sizes & styles. Worth seeing the different looks.
Attached are pictures of a 2004 SSB coupe in Florida that I passed on that had these rims mounted. Absolutely Gorgeous!! I should have bought this car!!
