re: swap a srt6 engine and trans in an NA coupe
You will need the transmission control unit and it wants to see a 3.07 rear gear which is why you need the diff. check with Rudy and validate this. Did you also get the heat exchanger, intercooler pump, mount and plumbing? Good luck with everything. You will need to work with Rudy to program the ECU to your car.
