Thread: Running Lights
Old Mar 19, 2011 | 11:43 AM
onehundred80
Default Re: Running Lights
Originally Posted by rusty
I want to use my fog lights as the unning lights instead of the headligts as it is now. I don't like the HIDs to be on as running lights. In Canada running lights are mandatory but I think the fog lights would be legal. Anyone have a suggestion that would allow me to make the change at areasonable cost or is it even possible. I understand that the OEM light switch on US Crossfires is different than the Canadian version????
I have a feeling that the Canadian headlights use a relay somehow. When you put it in gear the lights come on in a second but not instantly. This has to be triggered by a switch in the gear shift/parking brake area I suppose.
Disabling that switch would do the trick I'm thinking.
Does this switch trip a relay in the ICM (light switch)
With the switch disabled you would be free to do what you want.
I have found this gadget that allows auto operation of the high beams and it has a dimming feature in it. This way you would be using the regular halogens at a reduced power setting, this would save them from burning out too prematurely. My halogens lasted for 30,000 kilometers which was not bad I'm thinking.
Hamsar AUTOMATIC LOW-BEAM HEADLIGHT CONTROL - JCWhitney
It says low beams but why not hook it up to the high beams? I could of course be totally wrong and you cannot do that. Reduced power highs in the day should be OK.
DRL's are the front headlights, no rear lights are required.
