Running Lights
Old Mar 24, 2011 | 06:59 PM
  #41 (permalink)
Kane's Avatar
Banned
Default Re: Running Lights
After all of the talk about the super-secret $500 Canadian DRL module, it hope you gents know that you can wire the foglights to be DRL's quite handily with a $39 kit purchased off the web. NBD (no big deal).
Old Mar 24, 2011 | 07:39 PM
  #42 (permalink)
Are you are trying to show us something that is new to us and add a rare post about the Crossfire instead of furiously posting on the political forum? Then I would suggest you read more about what has been said before last November when you joined and gave us the dubious pleasure of your presence.
I'll let you into a secret. WAK (we already know)
Old Mar 24, 2011 | 08:01 PM
  #43 (permalink)
Kane's Avatar
Banned
And here I thought all the other folks were just plain wrong about you.
So tell me, 180, what was said before last November about $39 DRL fog lights? Seems rusty would like to know, too.
Old Mar 24, 2011 | 08:18 PM
  #44 (permalink)
This was a couple of years ago, and the guy got hosed for labor as the part costs $50 at Canadian Tire.
https://www.crossfireforum.org/forum...tml#post248995
Old Mar 24, 2011 | 08:48 PM
  #45 (permalink)
Kane's Avatar
Banned
What's this got to do with rusty's question? He wants to hook up his fog lights as DRL's, and he can DIY for about forty bucks. Plenty of simply kits on the web to choose from and it takes about 1/2 hour to install. Your little sister could do it, easy.
So rusty, if you want some help doing your DRL fog lights without a lot of BS, just PM me.
Old Mar 24, 2011 | 09:14 PM
  #46 (permalink)
Bob D's Avatar
We want to know the part number of it and the DRL optioned switch.
You've certainly validated my initial opinion...do you ever have anything positive to say or contribute?
This information was listed in RED in the previous post:
2005 Crossfire part #s: Current Chrysler parts list
5098638AA NO DRL
5098639AA DRL
6 others for export
The same numbers are listed for the 2008, didn't bother asking about 06/07.not interested.
Now another fly in the ointment. This is a private email from a forum user who bought an automatic in Kansas and finally was able to get the DRL activated> US or Canadian part number????
Why don't you do some homework and tell us?
The continuing saga , of how to get this 2006 Roadster registered. As we
all know Chrysler Canada, won't honor the warranty. Chrysler USA, won't
either. Now the dealers in Canada, begin to hover like the vultures they
are. Bob you were kind enough to explain that daytime running lights
could be programmed by the dealer to be turned on, since our car was an
automatic. Transitiowne Dodge in New York, new nothing about doing this,
but offered to change the headlight switch for $600 dollars U.S.
Needless to say they did not get the business. Brought the car to Grant
Menzies Chrysler in Whitby Ontario, they said they were aware of how to
program the switch, and that they charged 90 dollars for the service.
Fair enough we said, go ahead, came back to pick up the car, and they
said they had programmed the car, but that the switch would need to be
replaced in order for the new programming to work! In other words they
did us for a 100 bucks, and to add insult to injury, they wanted another
600 dollars Canadian for the switch. This will cost them, as none of my
fatherr's 2 other Chryslers will ever be serviced there again.
Anyway, we took the car to a local stereo/alarm shop, who said,
daytime running lights, oh yeah no problem, 20 minutes later, we were on
the road with the lights working.(another 100 bucks)
Old Mar 24, 2011 | 09:20 PM
  #47 (permalink)
Bob D's Avatar
So rusty, if you want some help doing your DRL fog lights without a lot of BS, just PM me.[/quote]
I initiated contact with Rusty last night but it sounds like you have a cheap solution so I'll leave it to you.
Old Mar 24, 2011 | 09:34 PM
  #48 (permalink)
I would have thought it obvious that the part mentioned can be used to do the headlights or the fog lights.
Old Mar 24, 2011 | 09:55 PM
  #49 (permalink)
I realize that you had mentioned the part numbers in your post yesterday but the parts list for 2004 lists a different number. You said you had no further interest in this subject,see the following, so I had to get other members who may be interested to verify the numbers.
Originally Posted by Bob D
Ok, time to put this to bed.
I believe in quality of information, not quantity.
I've been busy all week but have done some further investigation so I'll modify my initial entry after which I have no further interest in this matter:
The stereo shop fix used a module similar to the Canadian Tire one. That's the obvious conclusion for that scenario. No re-programing is required to get the lights to work, in fact no programing changes are required at all. Anyone who paid for programing changes got hosed.
Do I ever have anything positive to say or contribute?...........Nope.
5098638AA NO DRL
5098639AA DRL
6 others for export
Old Mar 24, 2011 | 10:23 PM
  #50 (permalink)
corfire's Avatar
I think rusty already has DRL's for his low beams with a Canadian switch. He needs to get those turned off (deactivated), so he can make the fogs DRL's. Yes, he can use a relay or buy a DRL (relay) kit for the fogs, but the real question has been: How can he get the Canadian DRL's turned off without replacing the OEM switch? He may have to buy or swap out for a US switch, and then add a relay for DRL Fogs, unless someone has a better idea.
Old Mar 24, 2011 | 11:06 PM
  #51 (permalink)
Changing to the US switch was my suggestion in post #2 (50 posts ago) on this thread.
But if a relay is in the Canadian switch, then by removing the wire that energizes it when the car goes into drive then the headlights on function would be eliminated. Other lights may still be on but the fogs could be added using a separate relay.
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
wruss
Feb 8, 2017 01:05 PM
waldig
Sep 2, 2015 11:02 AM
axnguyen
Jul 21, 2015 11:41 AM
