Thread: Running Lights
Old Mar 19, 2011 | 07:05 PM
onehundred80
Default Re: Running Lights
Dave you are on to something. The DRL's in my SRT, an American spec car with a CDN headlight switch do not function exactly like the DRL's in my Limited, a CDN spec car with CDN headlight switch. In particular with the engine running, when I place the Limited in Park or Neutral the headlamps turn off and the rest of the running lights stay on. This is not the case for the SRT, when the engine is running all of the running lights including headlights are on regardless of the transmission gear.
If there is a relay somewhere you should be able to here it when the lights go on. I probably could not hear but someone with a keen sense of hearing should be able to.
I have not found a circuit anywhere that shows the DRL circuit. Maybe a European service manual has it.
