If there is a relay somewhere you should be able to here it when the lights go on. I probably could not hear but someone with a keen sense of hearing should be able to.
I have not found a circuit anywhere that shows the DRL circuit. Maybe a European service manual has it.
Dave you're right about the DRL circuit not being documented. I have the hard copy service manuals and could not find it either. I will have to try to listen for a relay but it will be very difficult as it would happen at the same time as start up.
