Old Mar 21, 2011 | 05:28 PM
Sik Srt-6's Avatar
Sik Srt-6
Default Re: Do HIDs need a relay?
Originally Posted by parkerd
I like the halo lights. I'm thinking of putting them on mine as my drl's. I've seen a few right ups on them. How did you take the lights apart? In the oven or did you cut them apart? I'm also curious if the halos were hard to hook up.
I took them apart very carefully, using an exacto knife and cutting away carefully at the silicone sealant they use. Putting these lights in a oven will not work, they dont use a temperature cured sealant/adhesive. Others have cut the lense off, but i didnt really want to go that route. I wanted easer acess incase i needed to get to the CFL's or such.
As far as wiring the halos, im going a totaly different route then many others have. Im using some automotive style slealed thru connectors that i will use to run wires to and from the housing, then using a wireless remote switching moduel to contol the whole monstrosity. Im also doing the lower eyebrow mod as well. I actualy just finished wet sanding and polishing the lenses yesterday, time to get back on the project.
