Home made retaining clip
Hey guys, I am new to the forum. I burned a headlight out about 2 weeks ago. I went to the store and bought a new bulb, but didnt realize that I needed to disconnect the wires BEFORE trying to disconnect the retainer clip. So, I pulled on the retainer clip, and you guessed it, it came off of it's posts. Of course, in the process of trying to put it back in place, it fell down inside the headlight assembly.
The worst part of my story - this bulb wasn't even burned out. The only reason I was replacing it was because I wanted them both to be new and bright.
So anyway, back to my story. So, I drove the car around for about a week. Last Thursday, I get pulled over, and was given 10 days to get the light fixed. I tried and tried over the weekend to get the headlight assembly out of the car, but couldn't get the bottom screw(s) to come loose. I went to a garage yesterday, and he said it would take some time, but he would try to get the headlight assembly out so that he shake it till the metal clip fell out. I figured that would cost me some money... This morning, as I go to work on a military base, the MPs at the guard shack reminded me that my headlight was burned out, threatening a citation.
After work today, I looked at it, tried to get the assembly out, and of course had no luck. Then I thought, "why not use a paper clip and build a new clip?". So, with a paper clip, a pair of needle nose pliers, and a few minutes, my paper clip/retaining clip was created. It is not perfect, but will keep me from getting a citation.
Most of all, thank you to the forum for the very detailed pictures and instructions. I don't think I will touch my car again without first consulting the forum! You guys rock!!!!
Please note - the clip in the picture is too big. I got it in place, then had to pull it out and cut about a half inch or so off of the total length. It is holding well, for now. Thanks to whomever suggesting tying a string to the clip before re-installing. That bit of advice saved me from a 2nd clip inside the headlight assembly.
