Old Mar 30, 2011 | 09:34 AM
rmaier's Avatar
rmaier
Default re: swap a srt6 engine and trans in an NA coupe
I mainly need to know what wiring needs to be modified in the na car to accommodate the new S/C engine. The wiring harness is with the engine so no issues there and the SRT control module will be used as well. I was hoping to keep the 3.27 rearend from the na as it would be a little faster and just use the trans from the S/C car as I did not break the engine from the trans when removing them. I assume I need to rewire the fuse box for the 3 different fuses heat exch pump etc..... What I need to know is if I need to reprogram any of the computer modules to accomplish all of this ......and if so if I can accomplish that or need to send it off to have it done? Do I just swap out all of the modules from the srt and see if that will work in the na chassis ( with the rewire of specific srt fuses and acc) or do I leave the main module as well as the trans module and just swap the engine management computer?,
Thanks,
Robert
