Re: Project Log: 320 to AMG/SRT Level
Congrats on getting rid of the previous name, though i'm sure there is a way to change the name in your profile. Maybe a mod or Admin can help with that?
Anyway, I'm not sure about the S430 injectors, but I think just going one spec higher on the injectors would be all that you would ever need.
Also, I believe the engine is internally balanced, so I don't believe that changing the drive pulleys on this engine would have a long term detrimental effect, just don't go swapping out the dual mass flywheel for a single mass flywheel, if your car is a manual. Porsche engines have been known to have their crankshafts actually break in half due to the negative harmonics that are no longer being absorbed by the swap.
I'm looking forward to the day when you post up a dyno printout of all your mods.
Then we would need to find you someone on the forum with an SRT-6 that is in stock form (or can be switched to stock) to do a couple runs against, at a track.
BC.
