Old Aug 21, 2005 | 03:55 PM
danimal's Avatar
danimal
Default Re: Replaced Cup Holder
Originally Posted by PJA
Please post instructions for removal/replacement.
Thanks.
Pete
Remove trim plates around shift lever by pulling up and back. Remove the rubber cover from the emergency brake handle (this is the hardest part...it takes a lot of pulling). There are two screws at the front of the console and two nuts at the back (inside the storage compartment at the rear...pull carpet forward about two inches) that must be removed. Lift the console up from the front and slide forward. Disconnect any electrical connections and completely remove the console. Lay the console upside down (on a towel) and remove 4 torx screws holding the cup holder in place. Reverse the removal process to reinstall the console.
The storage cup snaps into place from the top of the console and can be done before or after reinstalling it.
Hope that was somewhat clear...if not, let me know. You can email me at: danimalb@iwon.com.
