Old Apr 9, 2011 | 10:02 PM
James1549
Default Re: Battery Dead. Should I expect any issues after replacing it?
Once the battery is installed and you start the engine, turn the wheel to right then left, almost stop to stop, and any lights on the dash should go out. Some of the replacement batteries are not quite as tall as the OEM, you may need a spacer to take up the slack on the mounting stud.
