Re: Squeaky Power windows
Sorry to resurrect this old thread, but I had my drivers side window start squeaking, and reading about the weather stripping possibly hardening and causing this, I used a q-tip with some Teflon Lube gel on it and coated the insides of the weather stripping that contacts the glass. I did this all around the window, not using a lot. Before you rush to do this, know that the teflon will streak the glass for awhile while raising and lowering. Even using windex, its a tough removal. Finally got it off by carefully using a paper towel with acetone on it (just damp, not dripping). Was this worth it? As of now (2 weeks later), smooth as silk with NO squeaking. I'll see how long it lasts ......
