Old Apr 12, 2011 | 06:53 AM
32krazy!'s Avatar
32krazy!
Default Re: Is this normal after a tune?
when you swapped all your mods did you knock off a vacuum line? mine did the same thing after installing the oil catch can. the cause was reusing the cork gaskets from rob. big no-no! they are 1 time use. ordered new cork gaskets from rob installed them and the high idle disappeared never to return!
