Old Apr 13, 2011 | 09:19 PM
loungn14's Avatar
loungn14
Default Re: Is this normal after a tune?
TPS....
also check for leaks. I have seen the tps do that many times. I have also seen minor leaks that do that as well.
Disconnect battery, let her sit and check again.
If still doing it..
Disconnect tb wire.
key to position 2. let sit for 2 mins
turn off
plug back in tb
key to position 2. Let sit for 2 mins, you will hear tb doing its reset procedure.
turn off
Start...
Also look for the small pipe that goes into the sc snout. It might have come loose.
