Old Apr 13, 2011 | 09:25 PM
oledoc2u
Default Re: Is this normal after a tune?
Originally Posted by loungn14
TPS....
also check for leaks. I have seen the tps do that many times. I have also seen minor leaks that do that as well.
Disconnect battery, let her sit and check again.
If still doing it..
Disconnect tb wire.
key to position 2. let sit for 2 mins
turn off
plug back in tb
key to position 2. Let sit for 2 mins, you will hear tb doing its reset procedure.
turn off
Start...
Also look for the small pipe that goes into the sc snout. It might have come loose.
that reminds me, my CSP sensor popped loose and cause mine to go nuts as well. I had to replace it, as one of the prongs cracked. Jake, I keep getting in too late to catch the guys. Any other phone #'s for after hours I can use...I tried yesterday, but no answer. I figured they were closed already, or on the road somewhere. I will shoot for tomorrow. PM me with any instructions I might need. I have already purchased and have a cable. Thanks man....
