Old Aug 24, 2005 | 07:02 AM
HDDP's Avatar
HDDP
Default SRT6 SC/IC Upgrade Parts & Prices
Here's the best list I could put together to upgrade our standard Crossfire to the specs of the SRT6. I'm still not clear if the ECU needs to be changed as well. I'll find that out ASAP. The braking system is also included, as well as the different cam shaft gear. Not sure if the cam shaft is different, another thing to check, but would explain the lower compression ratio. The prices are a bit confusing, the first price is the dealer price, the second is an online vendor I found. The total is at the bottom... It looks like a hell of alot better price than the $12,000 I was quoted by Kleeman, but this looks like it would be a hella do-it-yourself project !!! The parts schematics are in my gallery... I haven't seen anyone on the forum who can really answer the question if this modification is actually feasible without a nightmare of problems, so if any of the factory people would like to chime-in it would be appreciated.
Cooling, Intercooler, Intercooler, Intercooler - W/supercharger 1 $210.00 $156.24 $0.00 $156.24
Cooling, Intercooler, Intercooler, Insulator, Insulator - W/supercharger 1 $2.70 $1.98 $0.00 $1.98
Cooling, Intercooler, Bracket, Bracket - W/supercharger 1 $28.50 $21.08 $0.00 $21.08
Cooling, Intercooler, Connector hose, Connector hose - W/supercharger 1 $3.05 $2.26 $0.00 $2.26
Cooling, Intercooler, Outer hose, Insulator, Insulator - W/supercharger 1 $7.50 $5.58 $0.00 $5.58
Cooling, Intercooler, Air baffle, Air baffle - W/supercharger 1 $67.00 $49.60 $0.00 $49.60
Cooling, Intercooler, Intercooler, Bracket, Bracket Right - W/supercharger 1 $8.00 $5.95 $0.00 $5.95
Cooling, Intercooler, Pump, Pump - W/supercharger 1 $308.00 $228.16 $0.00 $228.16
Cooling, Intercooler, Clamp, Clamp - W/supercharger 1 $6.50 $4.84 $0.00 $4.84
Cooling, Intercooler, Outer hose, Clamp, Upper - W/supercharger 1 $2.00 $1.49 $0.00 $1.49
Cooling, Intercooler, Intercooler, Bracket, Bracket Left - W/supercharger 1 $8.00 $5.95 $0.00 $5.95
Cooling, Intercooler, Pump, Buffer, Buffer - W/supercharger 1 $4.40 $3.22 $0.00 $3.22
Cooling, Intercooler, Radiator hose, Radiator hose - W/supercharger 1 $13.00 $9.61 $0.00 $9.61
Cooling, Intercooler, Outer hose, Outer hose - W/supercharger 1 $40.00 $29.76 $0.00 $29.76
Cooling, Intercooler, Outer hose, Clamp, Lower - W/supercharger 1 $1.20 $0.87 $0.00 $0.87
Cooling, Belts and pulleys, Serpentine belt, W/supercharger, W/supercharger 1 $55.00 $40.92 $0.00 $40.92
Engine, Supercharger and components, Air duct, Air duct Right - W/supercharger 1 $227.19 $169.04 $0.00 $169.04
Engine, Supercharger and components, Air duct, Air duct Left - W/supercharger 1 $227.19 $169.04 $0.00 $169.04
Engine, Supercharger and components, Supercharger, Supercharger - W/supercharger 1 $2,140.00 $1,587.20 $0.00 $1,587.20
Engine, Supercharger and components, Tensioner, Tensioner - W/supercharger 1 $52.00 $38.44 $0.00 $38.44
Engine, Engine parts, Camshaft gear, Camshaft gear - W/supercharger 1 $61.00 $45.26 $0.00 $45.26
Engine, Engine parts, Crnkshft seal, Crnkshft seal - W/supercharger 2 $8.28 $6.98 $0.00 $13.96
Front suspension, Brake components, Caliper, Caliper Right - W/supercharger 1 $474.00 $352.16 $0.00 $352.16
Front suspension, Brake components, Caliper, Caliper Left - W/supercharger 1 $474.00 $352.16 $0.00 $352.16
Front suspension, Brake components, Rotor, Rotor Back - W/supercharger 2 $92.00 $68.20 $0.00 $136.40
Engine, Engine parts, Crnkshft damper, Bolt - W/supercharger 1 $3.20 $2.36 $0.00 $2.36
Exhaust system, Manifold, Exhaust manifold, Exhaust manifold Right - W/supercharger 1 $380.00 $282.72 $0.00 $282.72
Exhaust system, Manifold, Exhaust manifold, Exhaust manifold Left - W/supercharger 1 $340.00 $252.96 $0.00 $252.96
Exhaust system, Manifold, Exhaust manifold, Gasket, Gasket - W/supercharger 2 $2.20 $1.61 $0.00 $1.61
Total: $3,970.82
https://www.crossfireforum.org/galle...cat/500/page/1
