Old Apr 29, 2011 | 09:34 AM
dinasrt's Avatar
dinasrt
Default Re: Tweaked Stock Intake Manifolds from needswings
Originally Posted by mjgroves
I went back through and read the threads about 240's modded manifolds... and I'm still confused why boost decreases even though there's a clear increase in HP and torque. My brain is saying, "wait, less boost should be bad"... it needs a scientific explanation.
Also, I have a LET tune for the C3 pulley and NW dual, would I need to be retuned if I purchased these tweaked manis?
Thanks all for the responses!
I know you wanted a "scientific explanation", but there's no scientist here, so I'll give it to you in layman term. You know how when you take a running water garden hose and put your thumb over the end. You've restricted it and built the pressure up and the spray is more intense but there's less volume, same principle as a pressure washer. Yes pressure is part of the equation, but it's the Volume of air per minute that mixes and makes power for us.
