Old May 1, 2011 | 07:25 AM
oledoc2u
Default Re: Lack of Engine Power For SRT ?
Scotty, beautiful car btw....get that baby fixed....and hang on, because it has probably had this problem from the time you bought it...real power is about to come back. There is a "how to" here on the forum if you want to do it yourself...it can be done without removing the front bumper cover. Located on the right side below the fan area on the front lower corner of the motor. I would recommend the johnson over stock. There is a small difference in the fitting, but nothing to worry about. The hose clamp will pull donw enough to seal...good luck...
