Old May 1, 2011 | 03:43 PM
onehundred80
Default Re: Water Pump Replacement
Originally Posted by tighed1
I know it's tight in there but you could use the old "hose to the ear" trick to localize the area that the sound is coming from.
Hate to see ya replace a perfectly good water pump only to find out it is a bearing or something else!
I hate to suggest the hose trick, one slip and it could be in your ear.
I would suggest taking the belt off and rotating all the pulleys by hand and look for a rough and lumpy feel.
The bearing is protected by a seal and if the seal goes there should a leak out the front of the pump as well as a noise.
