Boiler, where did you get your spacers? I was looking at it and the fronts are flush with the wells, and the rears are inset somewhat, and I think you're right that spacers would look a bit better especially with that deeper rear dish. Anything in particular to know, hubcentric or something else? measuring them it looks like either 10 or 12 MM would be about right as you mentioned. Therefore do you also need longer lugbolts?
never mind Boiler, my question, as I just did a search and found my answer.
I see you found your answer, congrats. I personally would use nothing but hub centric spacers and definitely make sure you have enough bolt on the rear, but not too much because of the dreaded Ebrake
Good luck, I do think she will look good with spacers, and I got mine for $50 a pair, let me know if you want a link or the guys number...
