Re: Just need a little advise
You have not said if any water got in the trunk at all. If it did then the central locking pump buried under the foam and under the trunk mat causes all sorts of problems when it gets wet.
Look for the obvious first, do not get swung away from the moisture problem and the damage it can cause.
The ABS and battery problems would be a real coincidence.
