Old May 25, 2011 | 08:41 AM
jcprovost2's Avatar
jcprovost2
Default Re: Tire Pressure sensor
The dealer said need 4 tpms sensors. Can the batteries be changed(2004)? And read that the valve stem is the antenna and metal caps(not crossfire valve caps) will cause problems?
Originally Posted by rekcah
If you have an 04, the battery in the tpms is probably toast.
The magnet thing from what I've read only works if all the sensors are original and battery is functioning.
You can read more here
https://www.crossfireforum.org/forum...e-monitor.html
